1997 Lincoln Town Car
Suspension problem
1997 Lincoln Town Car V8 Two Wheel Drive Automatic 120000 miles
The wheels were changed with the switch on. The A/S light came on & the rear end dropped to the ground. I turned the switch off, started the car, & turned the switch back on. The car leveled out. I turned the switch off for 3 days to check for leaks. It stayed level. I turned the switch back on. The car stayed level for about a week. Then the rear dropped again. This time the pass. Side is lower than the D.S. I have tried several combinations of switch off & on with car runnign & not. It will not level out. The car normally parks on a slight down hill slope. Could this be a problem? Are there any sensors I can check? I have checked the fuses. Found one bad & replaced it.
May 14, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
