2CarPros - Car Questions & Answers
2005 Lincoln Other Repair Question
Topics covered: Engine, All wheel drive, Ignition coil.
Asked on February 22, 2010
2005 Other Lincoln Models Ignition Coil
Engine Mechanical problem
2005 Other Lincoln Models V8 All Wheel Drive Automatic 57000 miles
Over the past year all of the ignition coils have failed. Eachtime they have replaced the malfunctioning coil(s) and indicated they have found moisture in the cylinder. They have contacted Ford Engineering to seek their advice but the problem continues to occur. Can you suggest some areas to check that may lead to the area that is failing.
Thank you
Avatar Asked by Bill Hess
No Answer Yet
