2001 Lincoln LS Repair Question
Asked on December 18, 2008
2001 Lincoln LS Fuel pump
2001 Lincoln LS V8 Two Wheel Drive Automatic 129000 miles
I just replaced the fuel pump in my 01 lincoln ls. The main fuel pump is located behind the passenger rear seat bottom. The Jet pump to stabilize fuel in the saddle gas tank is behind the driver rear seat bottom under 6" rubber cover. When replacing fuel pump replace fuel filter also. Located in driver front wheel well behind skirting. If you get pump, and filter installed, and the car doesnt start its one of four things wrong.
1. Fuel pump shut off switch needs reset
2. Fuses blown ( there are 2 fuses. 1 is kick panel passenger side floor. 2 is in the trunk in the power distribution box)
3. Fuel pump Relay bad. (is in trunk P.D.B.)
4. Fuel Pump Diode bad. (is in trunk P.D.B.
