Mechanics
NO FIRE
Lincoln Continental
I have a 1996 lincoln continental with 4.6 motor I have no fire at the plugs have replaced crank and cam shaft position sensors I have 12 volts going to the coil I have removed the coils and had them checked they are fine. The check engine light the abs light and check traction control lights are all on. Car will not start it has 152000 miles. Please help
Lukesville4
May 7, 2007.
It sounds like the anti theft system is killing the spark. See if you have a valet switch, and try that! Or pull the fuse for it!
Merlin2021
Jun 19, 2007.
AD
