Lexus Other Repair Question
Asked on August 26, 2007
Trac and Engine Light
2001 ES300 Lexus V6
2 W/D with 72000 miles
Had new tires put on the vehicle last year. A couple of days later the Trac light and Engine light came on. I had it checked and the test showed P1155 code.
I had no other problems until a couple of weeks ago. When I crank the car if the weather is really hot outside, it dies out when I try to put it in gear.
If I keep my foot on the gas for a little while it will finally work okay. However, it sometime takes several tries to get to that point.
Drove to work today and the brake light is on now?
Please give me some feed back on this problem.
Thank you so much in advance for your help.
