1991 Lexus Other
My '91 Ls rear suspension seems to air up and deflate at will. It will hold air when filled and parked. When driving or parking at certain angles it will deflate. I also noticed the switch will not work at times to go from norm to high. It usually does not work after it has deflated (only the rear). If I disconnect the negative terminal from the battery for a few minutes it will air up and the switch will work again. Sometimes it will stay and sometimes it won't. I know there isn't a leak because it will stay aired up while parked for a couple of days. Is there some kind of sensor that may be causing this?
July 24, 2007.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
