1993 Lexus LS 400 Repair Question
Topics covered: Sensor, Camshaft, Check engine light.
Asked on August 4, 2010
1993 Lexus LS 400 won't stay running
Electrical problem
1993 Lexus LS 400 V8 Two Wheel Drive Automatic 089.50 miles
This vehicle sometimes is hard to crank but when carnk will run for a few munutes and will shut off and will not start for a while most of the times. one of the igniter is heating up more so than the other one is. I have changed the crank shaft sensor and still does the dame thing. It has been indicating code #15 which isn't on the listing of error on check engine light. I don't think that it is 24 for when jumper is used to access code the check engene light will flash one time, then after a couple of moments it will flash one log flash and the five quick flashes. This codes repeats it self. Is it a coil or camshaft sensor or some other problem.
