1993 Acura Integra There's a smell of exhaust
1993 ACURA INTEGRA
192,000 MILES • 4 CYL • 2WD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
I have a 1993 Acura Integra 192,000 miles. When the car is idling or at a stop light with the windows down. There's a smell of exhaust. Is there a leak from under the car? Please help!
Oct 7, 2010 at 11:47 PM
2CP-ARCHIVES
  • 4,540 POSTS
With the vehicle safely lifted, have a partner start the vehicle. Plug the tailpipe with a large rag pressed over the end of the pipe. Note the exhaust leaks under the vehicle. It should be a simple job. Determine if the cause is a gasket, rusted pipe, hole, etc. That will dictate how you fix the problem. Don't forget to look under the hood as the problem could be at the exhaust manifold as well.
Oct 7, 2010 at 11:51 PM
