1998 Lexus ES 300 Repair Question
Asked on February 15, 2008
1998 Lexus ES 300 Fuel Tank
Hello just wondering if you knew of an easy way to drain the fuel from the tank. Can't find a drain plug on the tank anywhere. Would like to avoid syphoning if possible. I think I read somewhere you can dissconnect the fuel from the engine then jt use the starter motor to drain the fuel out but would like to avoid draining the battery also if theres an easier way.
Cheers,
Gerome
