Resetting the alarm
1999 LEXUS ES 300
JES 7255
I set the alarm off by mistake. Now I try to start the car it will not start. The red alarm light continues to flash. How do I reset.
Nov 7, 2011 at 1:32 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,344 POSTS
Disconnect the battery For 30 minutes, then hook it back up again.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Close all doors, engine hood and luggage compartment door (trunk lid) and lock the car wait 30 minutes and unlock the drivers door with the key or remote this should work.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Cheers, Ken
Jul 13, 2017 at 6:50 PM
TRIAGE88
I changed dead battery and now the alarm won't let me start car. The alarm is from Lexus I have key alarm which has 3 buttons,( panic, unlock, lock). I only get check engine light on and the alarm keeps blinking I the a/c dash. How to reset alarm??
Jul 13, 2017 at 7:39 PM (Merged)
HMAC300
  • 48,601 POSTS
doors must be closed and locked.
TRIAGE88
I changed dead battery and now the alarm won't let me start car. Please help me reset alarm. I only get check engine light on when I put in key. The alarm light keeps blinking .
HMAC300
  • 48,601 POSTS
see pic
TRIAGE88
I tried what you mentioned, after a minute, I opened car and even with door opened the alarm light still blinking..
TRIAGE88
I had someone with a code reader come out and connect it to car, but it's not giving me anything on the reader.. Can it be y the alarm disabled car so I need to do a spefic alarm reset??
HMAC300
  • 48,601 POSTS
no you need a pro to read any codes as the code readers won't read any thing other than engine/trans and some can read abs. so it will have to go to a service center
JOSEPHINE1
1995 Lexus ES 300 6 cyl Front Wheel Drive Automatic 129,00 miles
the alarm on my car won't shut off. The battery went down when i left the lights on. I tried to charge it and now it wont do anything. when i unlock the car the alarm goes off
DAVE H
  • 13,384 POSTS
CHECKING THEFT DETERRENT SYSTEM WARNING (ALARM) OPERATION
Ensure theft deterrent system is set and indicator light is blinking. When hood is opened or any door is unlocked without using key, vehicle horns and theft deterrent horn will sound, and headlights and taillights will flash for approximately one minute. If doors are not locked when alarm is sounding, theft deterrent system will repeat door locking operation every 2 seconds during the one-minute alert time.
CANCELING THEFT DETERRENT SYSTEM SETTING (ALARM SOUNDING)
When system is set (armed) and the alarm is sounding, use one of the following methods to cancel the system setting:
Unlock left or right door with key.
Unlock doors with wireless door lock control system.
Insert key into ignition cylinder and turn to ACC or ON position.
Wait approximately one minute after alarm has sounded. After one minute, theft deterrent system will automatically reset in about 2 seconds if all doors are closed.
Disconnect theft deterrent ECU connectors. Measure voltage or resistance between following theft deterrent ECU connector T3 terminals. See Fig. 1 . If voltage or resistance is not as specified, repair wire harness or replace components as necessary. If voltage and resistance are as specified, theft deterrent ECU may be faulty.
T3-1 & Ground
With ignition switch in ST position and shift lever in "P", voltage should be 10-14 volts.
T3-2 & Ground
With ignition switch in ON position, voltage should be 10-14 volts.
T3-3 & T3-4
With ignition switch off, resistance should be less than 50 ohms.
T3-5 & T3-16
With luggage compartment door switch "pulled", voltage should be 10-14 volts.
T3-5 & T3-16
With luggage compartment door switch not "pulled", voltage should be less than one volt.
T3-6 & T3-16
With key inserted into key cylinder, resistance should be less than one ohm.
T3-6 & T3-16
With key not inserted into key cylinder, resistance should be one megohm or more.
T3-7 & T3-16
With passenger's door unlock detection switch on, resistance should be less than one ohm.
T3-7 & T3-16
With passenger's door unlock detection switch off, resistance should be one megohm or more.
T3-8 & T3-16
During all conditions, voltage should be 10-14 volts.
T3-9 & T3-16
Resistance on indicator light circuit should be less than one ohm.
T3-10 & T3-16
With door key lock and unlock switch in unlock position, resistance should be less than one ohm.
T3-10 & T3-16
With door key lock and unlock switch off or in lock position, resistance should be one megohm or more.
T3-11 & T3-16
With driver's door unlock detection switch on, resistance should be less than one ohm.
T3-11 & T3-16
With driver's door unlock detection switch off, resistance should be one megohm or more.
T3-12 & T3-16
With passenger's door open detection switch on (door open), resistance should be less than one ohm.
T3-12 & T3-16
With passenger's door open detection switch off (door closed), resistance should be one megohm or more.
T3-13 & T3-16
With driver's door open detection switch on (door open), resistance should be less than one ohm.
T3-13 & T3-16
With driver's door open detection switch off (door closed), resistance should be one megohm or more.
T3-14 & T3-16
With door key lock and unlock switch on (lock position), resistance should be less than one ohm.
T3-14 & T3-16
With door key lock and unlock switch off (unlock position), resistance should be one megohm or more.
T3-15 & T3-16
With key lock and unlock switch on (unlock position), resistance should be less than one ohm.
T3-15 & T3-16
With key lock and unlock switch off (lock position), resistance should be one megohm or more.
T3-16 & Ground
During all conditions, resistance should be less than one ohm.
T3-17 & T3-16
With door lock control switch on (lock position), resistance should be less than one ohm.
T3-17 & T3-16
With door lock control switch off (unlock position), resistance should be one megohm or more.
T3-18 & T3-16
With door lock control switch on (unlock position), resistance should be less than one ohm.
T3-18 & T3-16
With door lock control switch off (lock position), resistance should be one megohm or more.
T3-19 & T3-16
With luggage compartment door opener switch on, resistance should be less than one ohm.
T3-19 & T3-16
With luggage compartment door opener switch off, resistance should be one megohm or more.
T3-20 & T3-16
