1998 Rover Range Rover Repair Question
Topics covered: Thermostat, Engine, Water pump.
Asked on May 9, 2008
Range overheating
Engine Cooling problem
1998 Range Rover V8 Four Wheel Drive Automatic 103000 miles
Car overheats if driven for 2 to 3 miles but does not overheat parked and idling.
Thermostat looks to be OK. I flushed the system as well but problem persists.
I suspect water pump but don't know how to check if its pumping.
If it is the pump I can't get to all the bolts with the fan attached to the shaft. Can you please detail pump removal steps. Including how to get fan with clutch off the car.
Thanks
Thanks
Answer
Replied on May 9, 2008
You dont look at the thermostat and declare it-its good you have to test it or replace it cheap fix for the water pump see below
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
Its in the repair manual get one here see below links-
