1996 Rover Range Rover Repair Question
Topics covered: Flywheel, Wheel, Transmission.
Asked on October 14, 2007
1996 Range Rover 4.6 HSE Transmission problems
My trasmission was fine when I took it into the shop beacause of a rattling noise. It turned out that the flywheel was broken and needed to be replaced. When I picked it up the shifting felt a little different, then I turned it off and when I turned it back on, it wouldn't run at all. It felt like it was in park no matter what gear I put it in. Following morning I tried and it ran, didn't feel right, especially when I'd take off. Mechanic says my transmission is bad and I need to replace it. Claims that the broken flywheel damaged it. I never had any shifting problems until I picked it up from the shop. Is the mechanic right? and if so, how would the broken flywheel damage it. And why would't I feel anything before they replaced the flywheel?
Answer
Replied on January 5, 2010
it is possible the flywhell damaged the transmission .. are there any transmission fault codes stored in the PCM ?
