1987 Rover Range Rover Repair Question
Topics covered: Engine, Spark, Compression.
Asked on February 23, 2008
1987 Range Rover not starting
I have an 87 range rover that does not start. I have checked timing, replaced the coil and just did a tune up 2k miles ago. I tried using starting fluid to start it, but nothing. It has good spark from the coil and plugs. When trying to start, I can smell gas in the engine compartment near the intake. Could you please let me know what else to check before I take it to a shop. Thanks for any help !!
Answer
Replied on February 25, 2008
Could be flooded-remove sparkplug and verify it- If its not being caused by excessive fuel -check engine 's compression and re-verify valve and ignition timing-
If it has a distributor system remove D/cap and while cranking it over is the rotor turning? if not could be the T/belt or chain
