2000 Land Rover Freelander Repair Question
Topics covered: Wheel, Transmission, Axle.
Asked on June 29, 2009
Propshaft
Drive Train Axles Bearings problem
2000 Land Rover Freelander 4 cyl Four Wheel Drive Manual 80000 miles
hi,my landrover freelander has broken down in the middle of God's nowhere! i'm pretty sure it is the propshaft,but i 'm sure the transmission and front drive shafts are o.k......if i cut through/rip off the propshaft will i be able to drive it home(120 miles) front wheel drive?....does it have a limited slip diff?...will all the power just go to the spinning broken off prop?........is the front / rear wheel drive have a permenant 50/50 power split...even so,would breaking off the prop shaft cause catasrophic loss of lubricant/transmission oil? the engine is mounted front wheel drive style with the long propshaft...thankyou
Answer
Replied on July 8, 2009
you will lose all drive if you cut the shaft !!
