2000 Kia Sportage
Engine Performance problem
2000 Kia Sportage 4 cyl Four Wheel Drive Automatic
I checked the plugs and the third plug was really fouled out. I mean really black. I changed the plugs and swithed the coil packs around to see if it was a coil pack issue. I still came up with the third plug as a misfire. I don't have a fuel pressure tester so I took off the fuel filter and blew through it and no restriction. The car jumps at slow speeds, but at high speeds it doesn't. I even tested the plug wires, purge solenoid, canister clossed valve, tps, maf sensor, and iac.
September 12, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
