2000 Kia Other
Transmission problem
2000 Other Kia Models 4 cyl Front Wheel Drive Automatic 122000 miles
Hi, I have a kia carnival 2000 diesel. When I put the lever in D and the car go to forward ok, and then I put the lever in R and go towards back good, but after some 5 minutes did not respond lever any position. The next day the same thing. The OBD II sytem is good and shows no problem. The transmission is electronic, How I know if a mechanic or electronic problem, thanks.
Marco Altuna
July 27, 2008.
When was the last transmission Fluid and Filter Change?
Fluid should be Red or Pinkish if color is brown smell it it is most likely burnt and needs changed.
Jul 27, 2008.
