2004 Kia Optima Repair Question
Topics covered: Fuel filter, Fuel pump, Battery.
Asked on November 1, 2009
2004 Kia Optima fuel filter
2004 Kia Optima 6 cyl
where do i locate the fule filter needs replacement
Answer
Replied on November 9, 2009
FUEL FILTER
REPLACEMENT
Reduce the internal pressure of the fuel lines and hoses and perform the following operations.
Disconnect the fuel pump harness connector in the trunk room.
Start the engine and, after it stops, turn the ignition switch to OFF.
Disconnect the battery negative (-) terminal.
Connect the fuel pump harness connector.
Remove the two fitting nuts while holding the fuel filter nuts securely.
Remove the fuel filter mounting bolts, and then remove the fuel filter from the fuel filter clamp.
Tightening torque
Fuel filter fitting nut: 25-35 Nm (250-350 kg. cm, 18-25 Ib. ft)
Fig. 287: Locating Fuel Filter
