Mechanics
STARTING PROBLEM
1989 Jeep Wrangler
Engine Mechanical problem
1989 Jeep Wrangler 4 cyl Four Wheel Drive Manual
I have a 1989 Jeep Wrangler with a 2.5 engine. The engine will not start. It cranks over fine and there is spark. If you use a little bit of starting fluid it will fire and run just fine. After that it will start fine until you let it sit for awhile. I am at a loss as to what is causing tis problem as well as several mechanics I know. Any help would be appreciated.
AD
Roadworker13
September 18, 2009.
Check the fuel pressure if okay, test the ASD relay and fuel pump relay then report back with some testing results
Rasmataz
Sep 18, 2009.
AD
