car will not start
CHEVROLET IMPALA
IXBALL1
  • 7 POSTS
As I was driving, just stopped. I checked the timing and the timing belt and they seem to be ok. The car tries but does not turn over. I have checked numerous sensors and am now at a loss. What else could it be?
Jan 4, 2006 at 9:18 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,334 POSTS
Does the car have fuel pressure?
Jan 4, 2006 at 10:40 AM
IXBALL1
  • 7 POSTS
Yes, there is fuel pressure in the line (at the filter) and there was fuel in the line at the throttle body injector earlier but when I just checked the line at the throttle body injector was dry even after trying to start it a few times. Bad fuel pump? The relay on the fuel pump is good.
Jan 5, 2006 at 6:14 AM
IXBALL1
  • 7 POSTS
[quote="ixball1"]Yes, there is fuel pressure in the line (at the filter) and there was fuel in the line at the throttle body injector earlier but when I just checked the line at the throttle body injector was dry even after trying to start it a few times. Bad fuel pump? The relay on the fuel pump is good.[/quote]I did replace the fuel pump last summer however.
Jan 5, 2006 at 8:21 AM
  • 54,334 POSTS
Yes, try replacing the fuel pump
Jan 5, 2006 at 10:33 AM
IXBALL1
  • 7 POSTS
Replaced fuel pump, still no pressure at throttle body. Relay is good. Current is getting to fuel pump. At the end of my rope...don't know what else to try.
Jan 9, 2006 at 10:08 PM
  • 54,334 POSTS
the pump has power, and its a new pump and the pump dosn't run?
Jan 10, 2006 at 1:31 PM
IXBALL1
  • 7 POSTS
[quote="2CarPro Ken"]the pump has power, and its a new pump and the pump dosn't run?[/quote]
The pump is good, brand new part, but vehicle not getting fuel and still will not start still
Jan 10, 2006 at 4:30 PM
  • 54,334 POSTS
so it has fuel pressure but still wont start?
Jan 10, 2006 at 5:00 PM
IXBALL1
  • 7 POSTS
I am not sure if there is fuel pressure the pump is new have actually ordered a new fuel pressure regulator maybe that is the problem but I didn't know how to test the other so I have a new one ordered.
[quote="2CarPro Ken"]so it has fuel pressure but still wont start?[/quote]
Jan 11, 2006 at 6:57 PM
  • 54,334 POSTS
You need to check for fuel pressure first.
Jan 12, 2006 at 11:54 AM
IXBALL1
  • 7 POSTS
How do I check for fuel pressure?
[quote="2CarPro Ken"]You need to check for fuel pressure first.[/quote]
Jan 12, 2006 at 3:50 PM
