Would not start. Checked compression.
1&2 cylinders "o" compression.
Took head to shop had it repaired, valves planed etc.
Reinstalled all of engine.
Started ok then began to throw oil out of filler cap and PCV valve. Ran rough then smooth after removing PCV valve. Still had oil coming out at rev up.Comprssion check again and found #1 cylinder 72 and 2-3-4 at 92.
Took apart again but rings(were replaced) were ok and installed per book.
Why is this happening?
Sep 1, 2008 at 8:55 AM
