A/C problem
2005 JEEP LIBERTY
89,000 MILES
LAURENCE1
My a/c started blowing hot air on the way home from a long trip out of state. There was also a burning smell. I stopped at a 7-11 and a man there looked under the hood and said the compressor was locking up and it might need a new compressor but he said if I turned the a/c off I would probably be ok to make it the rest of the way home. I was afraid of breaking down so I stopped into a franchise auto shop but they were really busy and said they couldn't look at the car for several hours. As I was outside deciding what to do, one of the mechanics came out and I told him what the man at 7-11 had said. He looked under my hood for less than 2 minutes and said I needed a compressor. He did no other diagnostics whatsoever on my car, he went inside and ordered the part. A short while later, the part came and he took my car inside and installed it. I paid a lot of money and left. two hours later, I stopped to get something to eat. I went inside and my wife stayed in the car while it was running. It was then that she noticed the a/c started to blow hot air and the burning smell returned. I popped the hood and the new compressor was locking up. We drove for a few minutes and then the car began to overheat. We stopped and turned the car off and let it cool for awhile. Then we started the car up and left the a/c off and drove home an hour away. The car didn't overheat when the a/c was off. The next day, I took it to a mechanic who said it had a bad radiator fan assembly. My question is: was the first mechanic wrong to not have done any diagnostics to inspect the a/c system thoroughly to determine if I really needed a new compressor or not.Is it possible to determine if I needed a new compressor by looking at it for less than two minutes? Thanks for your help.
Aug 31, 2012 at 4:09 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Without any testings, it is not possible to know if the compressor is wrong.
Unless the compressor is tested to be seized do you require a new compressor. Other than that it could be the clutch that is faulty or wiring problem.
When the cooling fans don't work, the cooling efficiency of the compressor would be affected.
Aug 31, 2012 at 4:28 AM
TELISIA
Until now the air worked fine. It has 113,000 miles on it. The air blows extremely hot air. I had it Freon put in it and it still doesn't work. Then someone told me it might be my air compressor. How do I know if its my air compressor?
Jul 9, 2019 at 3:12 PM (Merged)
MERLIN2021
  • 17,250 POSTS
If the system checks out full, run a jumper wire to the compressor and see if it runs if not. If the compressor doesn't start bypass the high pressure switch too, if it still dosent start make sure all fuses are good then swap out the compressor. This guide will help
and
https://www.2carpros.com/articles/replace-air-conditioner-compressor
HEAVYDUTY
  • 60 POSTS
if someone added freon i would guess they checked the A/C compressor operation. Have someone pinch off one of the heater hoses near the firewall and see if the air gets colder. possible water shut off or air diverter door problem then.
WOOLSEY
I had this problem and had to replace the compressor cost me $324.00 all set I love this site.
MIKEHUGHES
Air Conditioning problem
2002 Jeep Liberty 6 cyl Four Wheel Drive Automatic 130k miles
AC not blowing cold air, compressor just keeps clicking on and off. What might be wrong and what is range of repair costs?
  • 110,190 POSTS
If the compressor is cycling quickly, chances are it is low on freon. I would estimate around 100.00 to have it recharged. However, I'm not sure of the average labor rate where you live so that could be a little off.
CCOURTRIGHT
  • 13 POSTS
When using AC for the first time this year, worked great for about 15 minutes then stopped blowing cold air. Turned the switch to vent. Turned back to AC after about 15 minutes and it worked again. Again it stopped working after about 15 minutes. Sometimes it will work for anywhere between 10 and 20 minutes. When turning the vehicle off and restarting, it works then too. Again for anywhere between 10 and 20 minutes. Each time, I turn the switch to vent and then back after a certain period of time. What would cause the AC to shut off after a certain period of time?
Jul 9, 2019 at 3:13 PM (Merged)
  • 31,937 POSTS
Get the refregrant level checked it may be low, if so there will be a leak that needs attention, do not add refregrant your self as over charging is a bad as under charging the system.
RICK59
Air conditioning not blowing cold enough inside. Checked vitals and found the following.
Ambient 88°F
With A/C on high for 10 minutes
Clutch engages and compressor turns without unusual noise. (maybe too quite)
Low Side PSI 63
Hi Side PSI 210
Center Vent Temp 70°F
Turned AC Off and got the following
Hi Side PSI 130
Center Vent Temp 105°F
The compressor is obviously doing some work.
Compressor Bad?
Orifice Bad?
Other?
Thanks for any help you can give me.
Thanks
Rick Hawkins
DOCFIXIT
  • 18,828 POSTS
By these readings it sounds like the compressor is weak and needs to be replaced here is a guide to help walk you through the repairs.
RICK59
Low on charge?
Wouldn't the low pressure be below the normal of 35-40 psi not way over at 63 psi if the refrigerant was low??
DOCFIXIT
  • 18,828 POSTS
That's why I asked about system beinging open and repairs. low side is high due to moisture or faulty blend door allow heat to enter evaporator. High side to low either low charge or compressor fault. so has system been opened or repaired?
RICK59
System has not been opened or repaired during the two plus years I have owned the vehicle. Air conditioning worked great until the recent past.
Any easy way to check the blend door function?
Took a reading of the vent temp with the air off the other day and it was 105F even though the ambient was 88.
DOCFIXIT
  • 18,828 POSTS
Please add some 134A I believe you will see low side go down and high up
RICK59
I had originally added refrigerant, a whole can, and the suction pressure was still high. So then, thinking I had overcharged I let some out, now who knows how much refrigerant is in there.
So since the last poste I did a complete recharge on the system.
Followed all of the correct procedures, using a very good vacuum pump and high accuracy vacuum guage.
Actually weighed the refrigerant going in and the charge is about 10 grams short on an ~ 650 gram charge. (I don't remember what the exact number was but I charged per the number under the hood)
The system now has the correct charge.
To diagnose the system I connected several temperature probes to the system lines.
The temperature probes were taped down on metal lines and insulated.
Following the system from the compressor.
The discharge line travels about 12 to 18 inches and enters the condenser.
The DISCHARGE PRESSURE port is in this span a few inches from the condenser inlet.
The CONDENSER INLET TEMPERATURE was taken a couple of inches from the condenser inlet.
The CONDENSER OUTLET TEMPERATURE was taken a couple of inches from the condenser outlet.
From here the line travels about 8 inches to the orifice tube.
The SUCTION PRESSURE port is a few inches after the orifice tube.
The SUCTION TEMPERATURE was taken adjacent to the SUCTION PRESSURE port.
From here the line travels (uninsulated) about 2.5 feet to the evaporator inlet.
The line exits the evaporator and goes directly into the suction accumulator.
The line out of the suction accumulator travels about 12-18 inches to the compressor.
The EVAPORATOR OUTLET TEMPERATURE was taken just after the suction accumulator.
The following are the readings taken after the recharge.
-At Idle
-Fan on high
-System running for 10 minutes or more
-Several sets of readings taken and remained constant.
DISCHARGE PRESSURE 225 psi
CONDENSER INLET TEMPERATURE 171°F (About 32° Superheat)
CONDENSER OUTLET TEMPERATURE 120°F (Good heat rejection across condenser)
SUCTION PRESSURE 64 psi (This is too high right? )
SUCTION TEMPERATURE 71°F (Chart says says PSI should be 71 so maybe slight superheat here but maybe temp and/or pressure gage slightly off)
EVAPORATOR OUTLET TEMPERATURE 102°F (This shows that the evaporator is absorbing heat)
CENTER VENT TEMPERATURE 76°F (My Plymouth van was making 62° immediately prior in the same ambient conditions)
AMBIENT TEMP DIRECTLY IN FRONT OF THE CONDENSER 93°F
Later I went out and took temperatures in three places.
1. Directly after the evaporator (which is directly before the accumulator)
2. Directly after the accumulator
3. Directly before the compressor
This showed about a 10°F rise in this span which may indicate that the refrigerant is leaving the evaporator as a gas and picking up superheat along the way to the compressor.
The compressor is quiet and doesn’t seem to make excess noise.
Sure would like to know for sure what is wrong with the system so I can replace the right thing the first time.
For what it's worth,
This system is somewhat different from my Plymouth Van which is as follows.
The compressor outlet goes into the condenser
From the condenser the line goes into some kind of small vessel. Possibly a drier.
From there the line goes into a TX valve which is directly before the evaporator. The high pressure port is located in this line after the condenser and before the TX valve.
The line then goes directly to the compressor with no accumulator. The suction port is in this span between the evaporator and the compressor.
DOCFIXIT
  • 18,828 POSTS
I show a fixed Orfice tube not a TVX. Two possibilities for elevated Suction blend door not shutting allowing heater core to warm evap. so acess through glove box see diagram
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_526.jpg
see if motor operates from warm to cold. other but have not seen in CCOT is Orfice tube damaged not droping pressure entering EVAP. any TEMP differential befoe and after Orfice?
HLACEFIELD
I had this problem and had to get a new compressor cost me $340.00 all fixed I love this site.
JEEP7L
my a/c only works when blowing from the bottom the top blows out warm what could be wrong with it?
You need to open it up and investigate the air blend/mix/mode actuators/vacuum operation and check the HVAC control module
JEEP7L
do you know around how much they charge to fix a problem like that?
It varies with locations parts and labor wise
CJ MEDEVAC
  • 11,004 POSTS
This may explain what's happening to yours. This is a Cherokee but similar to your set up. http://www.youtube.com/watch?v=kIWnuZ8vkEE --THE MEDIC
PROTECH1980
  • 901 POSTS
Nice video CJ, is'nt youtube a great thing.
EAGLE 1
2003 Jeep Liberty V8 Two Wheel Drive Automatic 50.000 miles
I have a liquid, clear, non evaporating, coming from the hose protruding from the fire wall passenger side. What is it? How can I correct this?
SERVICE WRITER
  • 9,123 POSTS
Sounds like the a/c vent drain tube. Condesation build up and runs off the evapoator core. This is normal and let it be.
PANTHER440
2004 Jeep Liberty air conditioning question. Compressor replaced last fall and ran cold. Compressor clutch not engaging now. Have used jump wire on low pressure switch and still didn't kick in. Applied separate 12 volt source to pigtail that sits on top of compressor and clutch engages that way. Engine compartment AC fuse is ok,,, Driver compartment AC fuse is ok. Why isn't the system delivering power to compressor clutch on its own ?
Check the AC relay-You sure it has the correct amount of freon
Wrench -you've taught me something here that I didn't know, sure appreicate-then again unable to view the diagram to give-shoot it in the dark-You have a great Happy Easter and take care buddy-Enjoy!
WRENCHTECH
  • 20,761 POSTS
You lost me Ras. You can view my diagram?
I don't know what switch he tried to jump but this system doesn't have a cycling/low pressure switch.
About the fuel pump relay from fuse no.14, there's no pressure switch in plain view-You have a nice day, out to find the golden egg-see you later
SHIRLEY GROTH
I have replaced the compressor and the high pressure switch and suction hose and it is still not working....Help!
LEGITIMATE007
  • 5,121 POSTS
[quote:8679c8d670="Shirley Groth"]Air Conditioning problem
2002 Jeep Liberty 6 cyl Four Wheel Drive Automatic 108 miles
I have replaced the compressor and the high pressure switch and suction hose and it is still not working....Help![/quote:8679c8d670]
hi
have you verified that the a/c fan is working when you, turn your ac on, and does it stay on for a good amount of time, or does it cycle off and on, also, does the compressor clutch cycle off and on frequently while the a/c is on?
WRENCHTECH
  • 20,761 POSTS
It has a 3 wire, 5v reference pressure switch that gives the PCM exact pressures for it to make decisions. The A/C clutch relay is powered by the fuel pump relay.
This where I lost you w/o the fuel pump relay-No AC-something new
WRENCHTECH
  • 20,761 POSTS
Why would you need A/C if the car isn't running?
JDE
My wifes Liberty's AC will work fine when you first start the vehicle. Then, after driving about 10-15 minutes, the ac blows warm air (non air conditioned). Intermittently, while driving at highway speeds (60+) the ac occasionally will come to life, and start blowing cold air. This usually only lasts several minutes before losing its cold air. I have checked/replaced the clutch compressor relay without any change. A friend suggested replacing the radiator fan module. Does this sound like a viable solution? Do you have any idea what might be causing the problem? Thank You!
Jul 9, 2019 at 3:14 PM (Merged)
MERLIN2021
  • 17,250 POSTS
first thing ie refrigerant check! if it's low the compressor is cycling on and off too much, or if freon is too low it's not cycling at all. If the charge is ok, check the high and low pressure switches.
DONNA DUCE
How do you check the high low switches?
Hi Donna,
This post is pretty old so I will jump in and provide the info. If you have an issue please post a new thread and give us the detail of your vehicle and issue and we will help however we can.
Thanks
