2003 Jeep Laredo Repair Question
Asked on July 7, 2010
Won't switch out of 2nd/3rd gear
Transmission problem
2003 Jeep Laredo 6 cyl Two Wheel Drive Automatic 160000 miles
within last 6-9months had crank shaft position sensor replaced & throttle position sensor replaced, was running fine, then my husband decided to clean the engine (had some minor oil leaking residue) with high pressure washer, now it won't shift out of 2nd/3rd gear. At 50/55 mph, the rpms are at 2/2.5 when it should be at 1.5/2. Do you think he got water in one of the sensors or something?
