1998 Jeep Cherokee Repair Question
Asked on October 8, 2007
98 Sport, how do I replace door hinge pin?
1998 Jeep Cherokee Sport 4.0l w/ 250k. I have a sagging driver's side door, I was wondering if and how I can replace the hinge pin and bushings, or, do I have to cut the welds and replace the entire hinge assembly.
When I lift up on the door, it seems very obvious that the problem is the upper pin and bushings, the bottom doesn't seem to move. Also, the welds look good on upper and lower hinges. Thank-you for any help, I want to fix it but not sure which route to take or if I have the options right.
Cheers!
Cheers!
