Brake lines leak?
EVERETTRAMEY
  • 2001 JEEP CHEROKEE
  • 4.0L
  • 4 CYL
  • 4WD
  • 200,000 MILES
I can see it leaking from the driver's side at the bottom. I was trying to see where the brake lines is located.
Thursday, November 3rd, 2016 AT 4:38 PM
CARADIODOC
  • 33,729 POSTS
Here are videos to help you make your own line or replace the brake flex hose.
https://youtu.be/sO43p4ZFUiM
and
https://youtu.be/1Prs_coIuCg
The process is the same in most cases.
Thursday, November 3rd, 2016 AT 5:14 PM
EVERETTRAMEY
Where are the brake lines located at?
Thursday, November 3rd, 2016 AT 5:43 PM
CARADIODOC
  • 33,729 POSTS
A rubber flex hose is attached to each front brake caliper and each rear wheel assembly. The other end is clipped to a bracket on the body sheet metal, and a steel line attaches there to each rubber hose. Where those lines go depends on whether the car has anti-lock brakes or standard brakes.
Thursday, November 3rd, 2016 AT 6:21 PM
SGBIGNASTY1027
  • 1997 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 147,658 MILES
My 97 cherokee sport has a brake fluid leak on the right front side. It looks like the fluid is comin from this soft rubber looking thing thats behind the pads. What is this and how can I fix it? Thanks.
Thursday, May 20th, 2021 AT 10:18 AM (Merged)
  • 108,133 POSTS
If the rubber thing is round, it is a dust cover. The caliper piston rides in it. If it is leaking, the caliper needs replaced.
MIBUBIO
  • 5 POSTS
  • 1995 JEEP CHEROKEE
I changed my rear brake shoes, and what I think is the brake wheel cylinder when I started bleeding the brakes it start pouring out, theres two seals on each side (rubber seals), and one of them is there but not around and wont go back on, that side brake shoe is also out about an inch on the top where its supposed to be, do you by any chance now how to make it flush with the top where the two shoes meet, and what to do to stop the master cylinder from leaking?
Take it all apart and start from scratch-replace the wheel cylinder-anchor the brake shoe on the anchor point on top then put cup spring, then set the brake adjuster star wheel to expand or contract the shoes
When you put back the drum and it will not go thru readjust the star wheel till the drum can set in. When done do a couple of reverse backing while stepping the brake this will set the clearance between the shoe and drum.
