2CarPros - Car Questions & Answers
1996 Jeep Cherokee Repair Question
Topics covered: Engine, Gas, Distributor.
Asked on May 10, 2006
1996 Jeep Cherokee 4.0L Fuel Pump Problem
My 1996 Jeep Cherokee Sport will not start. I checked the fuel pressure and there wasn't any. I checked for the humm in the gas tank and there wasn't any. I found the relay in the Power Distr. box and measured the voltage across the coil of the relay and I would see it jump to 12V when the key was turned to the run position but instantly fall to 6.5V, which I believe is not enough to pull in the relay. From the Chilton book I have it looks like the low side of the coil is connected to the ECU so I'm thinking I have a problem with the ECU. Any suggestions.
Avatar Asked by goski
Answer
Replied on July 10, 2006
Tap on your gas tank and see if the humming starts. I had to do this to trip the pump. Might need a new pump soon.
Tiny Answered by jdh1jdh1
0 questions asked
Replied on August 1, 2006
you may also want to try to find a disconnected ground wire on the left side of the engine block. Had that problem before. left side when your facing the engine, just past and a bit below the distributor.
Tiny Answered by nunavut
10 questions asked
