Mechanics
CHEREKEE
1995 Jeep Grand Cherokee • 186,000 miles
Wont start, replaced, cap, rotor, plugs, wires camsensor. Cranksensor, fuelpump and sender unit. Compression test, and checked fuses, and relays. I do have a spark and am getting gas to fuel rail, Will not start with all these new parts.
Jeepstir
May 7, 2013.
Have you tried testing for trouble codes? Have you checked the fuel injectors for voltage and ground?
To check for codes, you turn the key just till the dash lites come on, no further. Cycle the key, on--off, on--off, on--off, on, then the mil on the dash starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
JDL
May 7, 2013.
I checked codes and got 12 55, No I did not check fuel injectors for voltage and grn. How do I do that? I do have muilti meter, give me some direction
Jeepstir
May 7, 2013.
What is the compression suposed to be on the cylinders? Im reading 110-120-120-120-124-124
AD
Jeepstir
May 7, 2013.
You have to do testing with engine cranking. Did you check for spark with engine cranking?
In the diagram, for fuel injectors, the top wire is voltage. The bottom wire is ground. Check with engine cranking. You might be able to check injector pulse, using a noid lite. I'm not sure your digital multimeter will check for a pulse? It will if it has a min/max feature. Might work with tach or duty cycle setting?
JDL
May 7, 2013.
YES, I check for spark while motor is cranking, dont know any other way to do it.I do not have noid lights.
When trying to start the motor sounds like its trying to start just wont come all the way.
Jeepstir
May 7, 2013.
In the diagram, for fuel injectors, the top wire is voltage, Ok which is top wire? Mine are side by side. Got a color code? And what voltage am I looking for?
Jeepstir
May 7, 2013.
You don't have to keep popping questions. I'll get to you as quick as I can. Your not the only person I'm trying to help. All your doing is clogging up my email.
Give a dam second and I'll try to post diagram. I doubt it will help you, I'll try anyway.
JDL
May 7, 2013.
Hope it works this time.
http://s13.postimg.org/wt0piq9fb/fuel_injectors.jpg
how to take a screen shot
The normal compression is around 120--150 psi. The difference between cylinders should be more than 30 psi.
JDL
May 7, 2013.
Okay Im done with you pal, have a nice day.
Jeepstir
May 8, 2013.
Didn't mean to be rude. As far as the fuel injectors in the diagram, look at the wire colors. In the diagram the top wires are voltage, dark green with black tracer. The bottom wire is ground controlled by the pcm.
Hope you got it fixed by now. Sometimes I'm trying to help several people at the same time. It can get frustrating, not your fault.
I try to help everybody the same, whether they donated or not. Usually you can get your donation back if you don't like the answer. I don't control donations.
JDL
Mar 25, 2014.
AD
