Mechanics
INSTRUMENT CLUSTER LIGHTING
2000 Jaguar XK8
Electrical problem
2000 Jaguar XK8 V8 Two Wheel Drive Automatic 63000 miles
Last week when I went to drive home at night, my instrument lighting did not work when the headlights are on. When I put the key in the ignition they are on, but when I rotate the lighting stick to put on the headlights the instrument lighting shuts off. I checked the dimmer switch to make sure that it is not turned down and that is not the case. Any ideas?
Daverobinson
September 8, 2010.
Mine did the same thing. It was a 10 amp fuse on pass side inner dash.
Planetpuleo
Sep 17, 2010.
AD
