How do I reset the alarm so I can start my car?
1993 JAGUAR XJS
50,000 MILES
SASHANMAN
I can not start my car. I can not lock or unlock my car. I can unlock my car with my key. AAA came and could not start the car. Battery is good.
Nov 12, 2011 at 3:05 AM
FIXITMR
  • CAR REPAIR CONTRIBUTOR
  • 9,990 POSTS
This will work. The specific sequence to enable security system programming for 1993 and 1994 XJ6 is:
Ignition key off
Security switch (in center console) on
Ignition on, position 1
Security switch off
Ignition off
Toggle security switch 5 times.
At this point, you should hear a tone which notifies you that the system is in programing mode and you could program a remote, if you had one. My guess is that you would be able to start the car at this point.
Nov 12, 2011 at 4:22 AM
SASHANMAN
Thank you. It worked. The alarm is beeping and will not unlock or lock the car. I can start the car.
Nov 12, 2011 at 10:06 PM
FIXITMR
  • 9,990 POSTS
oops. how many remotes do you have? there are 5 remote learning slots. you must fill all slots even if you dont have 5 remotes. after initial chirp/headlight flash, Press arm/lock you should hear 1 tone. rock valet 1 time you should hear 2 chirps press arm/lock of same or another remote, hear2 tones, rock valet 1 time, 3 chirps, etc up to 5.
Nov 13, 2011 at 12:59 AM
MDELMONEGO
The door handles wet relaced,on the drivers side of my jaguar xj6 1996,I have only a key no remote, and the alarm will not shut off how to turn off, so I can start
Oct 28, 2016 at 7:35 AM
JAGUAROWNER
Do not have fob to disarm the system and no manuals with car.
Mar 6, 2017 at 9:47 AM (Merged)
STEVE W.
  • 15,157 POSTS
On US models the key in the door and turned to unlock the door turns off the alarm. The rest of the world needs the remotes.
JAGUAROWNER
Does trunk have to lock too?
  • 54,334 POSTS
Yes the trunk has a lock as well.
RBI
Interior problem
1995 Jaguar XJS 6 cyl Two Wheel Drive Automatic
The brochure that came with our car purchased used gives says:
To lock car and arm the system, press once, to turn on headlights after arming/locking, press again w/i 3 seconds, to unlock car and disarm the system, press once.
When I press once, I get an audible beep, but the doors don't lock. When I press again, the headlights come on. When I press the third time, I get two audible beeps.
Instructions also say "to turn system on/off, press switch located in the center stowage box. I'm presuming this is the stowage box between the driver and passenger seat. I cannot find any switch there.
Can you provide any guidance?
Thanks,
R.B.Irwin
JAGALL72
How do I disable my alarm system for my 1996 Jaguar xj6
Mar 18, 2017 at 2:18 PM
  • 54,334 POSTS
Here is a link that should help
https://www.2carpros.com/articles/how-to-reset-a-security-system
Best, Ken
Mar 22, 2017 at 2:46 PM
