1990 Jaguar XJS wont start
1990 JAGUAR XJS
50,000 MILES • V12 • 2WD • AUTOMATIC
GASOHOLIC
today i replaced the battery in the car,i replaced the battery in the remote for the alarm ,and replaced the spark plugs and the B side fuel rail regulator and everything is correctly installed .went to start engine now i dont seen to have spark from the coils a or b engine just turns over ive tried the remote, sevral times it works but i sence the alarm wont deactivate the secruity start feature. how do i disarm this feacture so car will run . i looked for a fuse or wire to unplug cant locate either.. update.... to disarm the alarm remove the driverside fuse panel under the steering colume look for a single fuse holder remove fuse problem solved .......
Mar 6, 2010 at 9:09 AM
