1976 Jaguar XJ6
1976 Jaguar XJ6 V8
Hello, I have a 350 chevy engine with a fairly standard carter AFB carb. I have been having trouble for some time figuring out why one side of the carb will not provide enough fuel at idle. If I squirt fuel into the left side of the carb the engine idles normally, when I stop it starves the 4 cylinders fed by this side of the carb. The engine has an intake that separates the plenum under the carb so each side of the carb supplies only 4 cylinders. When no fuel is added to the left side the cylinders fed by it do not fire which I checked by pulling wires to those cylinders and there is no change in engine rpm but there is very noticeably with the right side. I have dismantled, cleaned and rebuilt the carb and nothing seemed to change. Any help will be very much appreciated. Thank you!
Charles fowlkes
July 7, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
