Gear box fault
MERCYME15
  • 2003 JAGUAR X-TYPE
Engine Mechanical problem 6 cyl All Wheel Drive Automatic 76,592 miles
this morning my x type 2.5 started, but when I turned it off for approx 5 minutes it would not restart. It took several attempts after which it started, but with the message centre reflected this message, "GearBox Fault - which it states. It is likely the driver will expericene a degradation of th gearbox operation.
What is pray tell is the problem? I was able to drive it home.
Your assistance is appreciated.
thx
ly - Phila, Pa
Saturday, February 27th, 2010 AT 12:12 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
It sounds like you have an input or output shaft speed sensor that is out causing the transmission to have limited operation.
To confirm the problem let's run the codes to see what comes up. This guide will help you.
Here is a factory bulletin as well.
https://www.2carpros.com/forum/automotive_pictures/266999_jag_74.jpg
Please run this test and get back to us.
Cheers, Ken
Saturday, November 18th, 2017 AT 8:15 PM
NITABUG86
Electrical problem
2003 Jaguar X-Type 6 cyl Front Wheel Drive Automatic
Waht does the message gearbox fault mean?
Saturday, November 18th, 2017 AT 8:16 PM (Merged)
DAVE H
  • 13,383 POSTS
Have the vehicle plugged into a diagnostic computer to locate the cause of the fault
BEOWOLF2009
  • 2002 JAGUAR X-TYPE
  • 6 CYL
  • AWD
  • 57,000 MILES
2002 Jaguar X-Type 6 cyl All Wheel Drive Automatic 57,000 miles
The engine light symbol came on and the digital readout said gear box
DAVE H
  • 13,383 POSTS
Have the vehicle plugged into a diagnostic computer to retrieve the fault codes stored
RAMONA460
Transmission problem
2002 Jaguar X-Type Four Wheel Drive Automatic 191793 miles
i have 2codes p1647p1000 an I think something maybe wrong with the tranmistion
DAVE H
  • 13,383 POSTS
Have the vehicle plugged into a diagnostic computer to check for transmission related codes
2CP-ARCHIVES
  • 4,542 POSTS
  • 130,000 MILES
How do you get the gear box fault light off and what's makes it come on
SATURNTECH9
  • 30,870 POSTS
Your going to have to have to have the computer scanned for codes thats your first step andlet me know the exact code numbers not code descriptions?You can try a diyer scan but might need a more advanced scan tool to read them.
Saturday, November 18th, 2017 AT 8:17 PM (Merged)
