Brake warning light is on I need brakes
ANONYMOUS
  • 2007 JAGUAR S-TYPE
  • 62,000 MILES
The brake warning light is on I need to do a brake job can you help me please?
Wednesday, March 13th, 2013 AT 9:57 AM
  • 108,170 POSTS
Rear brake pads and rotors aren't too hard to replace. You can expect them to last approx 30,000 miles. I suggest getting a lifetime pad so you never have to pay for them again.
First, here is a link that shows in general how it's done. You can use this as a guide.
https://www.2carpros.com/articles/how-to-replace-rear-brake-pads-and-rotors
Here are the directions specific to your vehicle. The pics below correlate with the directions.
________________________________
2007 Jaguar S-Type (X200) V6-3.0L
Brake Pads - Vehicles With: Standard Brakes, VIN Range: M45255->N52206
Vehicle Brakes and Traction Control Disc Brake System Brake Pad Service and Repair Procedures Rear Disc Brake Brake Pads - Vehicles With: Standard Brakes, VIN Range: M45255->N52206
BRAKE PADS - VEHICLES WITH: STANDARD BRAKES, VIN RANGE: M45255->N52206
Brake Pads - Vehicles With: Standard Brakes, VIN Range: M45255->N52206 (70.40.03)
pic 1
Special Service Tools
Removal
1. Remove both rear wheels and tires.
pic 2
2. NOTE: Left-hand shown, right-hand similar.
Detach the brake caliper.
Remove and discard the brake caliper retaining bolts.
pic 3
3. CAUTION: The brake caliper must be supported at all times.
Using a suitable tie strap, secure the caliper to one side.
pic 4
4. NOTE: Left-hand shown, right-hand similar.
Remove the brake pads.
Remove the brake pad anti-rattle spring plates.
Installation
pic 5
1. WARNING: Do not use compressed air to disperse brake dust into the atmosphere.
CAUTION: If the pistons are pushed back into the housing, brake fluid will be forced back into the brake fluid reservoir.
CAUTION: Make sure that the brake disc faces are clean before installation. A!
CAUTION: Brake pads must always be replaced in axle sets.
NOTE: Remove the forcing screw from the crankshaft pulley/damper remover and install to the brake caliper piston retractor tool.
Using the special tools, fully retract the brake caliper pistons.
pic 6
Make sure the brake caliper piston location mark is in the correct position so that the locator pin on the brake pad locates correctly into the brake caliper piston.
pic 7
3. NOTE: Remove the forcing screw from the brake caliper piston retractor tool and install to the crankshaft pulley/damper remover.
Install new brake pads.
Install the brake pad anti-rattle spring plates.
pic 8
4. CAUTION: The brake caliper must be supported at all times.
Remove the tie strap.
pic 9
5. NOTE: Left-hand shown, right-hand similar.
Attach the caliper.
Install new brake caliper retaining bolts.
Tighten to 34 Nm.
6. Install both rear wheels and tires.
7. NOTE: Do not start the engine or operate the electronic park brake before depressing the brake pedal.
Repeatedly depress the brake pedal until brake pressure is evident.
I hope this helps. Let me know if you have other questions.
Take care and God Bless,
Sunday, February 28th, 2021 AT 6:09 PM
2CP-ARCHIVES
  • 4,542 POSTS
  • 2003 JAGUAR S-TYPE
  • 88,000 MILES
I need step by step instructions to replace the rear brake pads. I'm unable to remove the caliper (caliper bolts have been removed and the old pads seem to be locked onto the rotor. Does this have something to do with the electronic parking brake automatically setting when the car is shut off?
Monday, March 1st, 2021 AT 1:49 PM (Merged)
  • 52,797 POSTS
Removal
Carry out the parking brake cable tension release procedure.
Detach the parking brake cable.
Reposition the brake caliper lever.
Release the retaining tangs.
Rotate the brake caliper upwards.
Remove and discard the brake caliper lower retaining bolt.
Installation
WARNING: DO NOT USE A COMPRESSED AIR TO DISPERSE BRAKE DUST INTO THE ATMOSPHERE.
Install a new brake caliper lower retaining bolt.
Tighten to 34 Nm.
Attach the parking brake cable.
DAVIDA2
  • 2001 JAGUAR S-TYPE
  • 6 CYL
  • 77,000 MILES
Please give me instructions onhow toremove read break pads 01 s type.
DAVE H
  • 13,383 POSTS
REAR DISC BRAKE PADS - VEHICLES WITH: STANDARD BRAKES, VIN RANGE: M45255->N52047 (70.40.03)
Removal
NOTE:Special tools required: Brake Caliper Piston Retractor Tool (206-080). See Fig. 39. Crankshaft Pulley/Damper Remover (303-588). See Fig. 40.
Remove both rear wheels and tires. For additional information, refer to WHEEL AND TIRE (74.20.05)
NOTE:Left-hand shown, right-hand similar.
Fig. 22: Removing Brake Caliper Retaining Bolts
Courtesy of JAGUAR CARS, INC.
CAUTION:The brake caliper must be supported at all times.
Fig. 23: Securing Caliper To One Side Using Suitable Tie Strap
Fig. 24: Removing Brake Pads
Installation
WARNING:Do not use compressed air to disperse brake dust into the atmosphere.
CAUTION:If the pistons are pushed back into the housing, brake fluid will be forced back into the brake fluid reservoir.
CAUTION:Make sure that the brake disc faces are clean before installation.
CAUTION:Brake pads must always be replaced in axle sets.
NOTE:Remove the forcing screw from the crankshaft pulley/damper remover and install to the brake caliper piston retractor tool.
Fig. 25: Retracting Brake Caliper Pistons Using Special Tools
Fig. 26: Identifying Brake Caliper Piston Location Mark
NOTE:Remove the forcing screw from the brake caliper piston retractor tool and install to the crankshaft pulley/damper remover.
Fig. 27: Installing Brake Pad Anti-Rattle Spring Plates
Fig. 28: Removing Tie Strap
Fig. 29: Installing Brake Caliper Retaining Bolts
Attach the caliper.
Tighten to 34 N.M.
Install both rear wheels and tires. For additional information, refer to WHEEL AND TIRE (74.20.05)
NOTE:Do not start the engine or operate the electronic park brake before depressing the brake pedal.
