2000 Other Jaguar Models high amp draw
2000 JAGUAR
47,000 MILES • V8 • 2WD • AUTOMATIC
UMPIREOH23
I took you suggestion and disconnect the (+) wire from the alternator. It did not change the amp draw.
When I take out the 40amp fuse the high draw goes away. A small draw still remains. I found the fuse that has the small draw on it. When I remove that all amo draw goes away.
COULD the entire fuse panel be bad?
I am not sure what they 40 controls other that what it says is the primary junction bix
I am not sure what to do next.
Mar 1, 2008 at 12:25 PM
