Problem with unstable RPM while moving
DANIELASKING
  • 2007 HONDA CITY
  • 4 CYL
  • FWD
  • 55,000 MILES
I am driving a Honda City idsi 2007 model. Recently the car has some problems with unstable rpm. While stationary, the idling is very stable. However while on the move, the rpm will fluctuate by around 300rpm more and come back down. This process repeats itself despite the accelerator is maintained at the same position. At times when moving off, the rpm will go up but the car does not move. Then suddenly the power will connect and the car will dash forward. The engine problem light was not activated.
Do you
have the same problem?
Friday, February 18th, 2011 AT 2:38 AM
KHLOW2008
  • 41,815 POSTS
I have seen this happen when the throttle actuator is dirty causing the sensor and the acautor to lose their correlation. Here is a guide that will help you see how to fix the problem, disconnect the battery before you begin.
Friday, February 18th, 2011 AT 3:25 PM
TWOOFUS
  • 0 POST
Thanks for this post I had this problem and the service fixed it. I love this site.
Monday, February 11th, 2019 AT 4:25 PM
WASAY SHEIKH
  • 2007 HONDA CITY
  • 112,000 MILES
My car's RPM has started fluctuating ever since I got the throttle body serviced. The rpm rose beyond 1000, after the service.I noticed it and the next day I asked my mechanic to fix it, because earlier on it was perfectly stable and the car was giving good mileage too. He very reluctantly slowed it down by turning a screw with an allen key on the throttle body, where the throttle plate rests. With that, for the time being the RPM came down to normal but started fluctuating when the air-conditioner was turned on. When the radiator fan starts automatically, the RPM drops slightly as if the engine was about to stall, but then gains and comes back to normal. This is felt more when you are driving in town and in traffic where u have to stop at traffic lights etc. Hardly felt on a long drive or highway. A Honda pitstop mechanic, whom I went to lately, reset the entire thing, using a computer but my car is still not the same. Pls advise!
Monday, February 11th, 2019 AT 4:26 PM (Merged)
  • 52,797 POSTS
The cleaners today take a coating off the throttle bodies and tend to cause this kind of issue. You are not to have them cleaned as per the manufacturer. Most likely the throttle body has to be replaced.
WASAY SHEIKH
Thank u very much Roy.I will start looking for it cos I doubt if the spare part dealers keep brand new throttle bodies cos anyone hardly changes them. However I will check the market. Thanks again.
JAC76
  • 1987 HONDA CITY
  • 4 CYL
  • FWD
  • 150,000 MILES
My friend and I just replaced the cylinder head in my 1987 honda civic and took it out for a short test drive (5 mi). On our return trip, the car suddenly was hard to control, but we made it back safe (whew). When I parked the rpm's were at 4000 (!), Same when in neutral. Gas pedal seems normal. We think we probably knocked something out of place in the carburetor when installing the head - any thoughts?
SERVICE WRITER
  • 9,123 POSTS
I'm not familiar with a Honda City. Typo?
Sounds like a possible vacuum leak. Go over your work and look for anything not reconnected or rotted rubber and leaking.
Don't run it too long, but listen for a hissing sound as the engine idles.
JAC76
It idles at 4000 rpm -so I can't hear anything (!) But the engine. Had no idea a vacuum leak could do this, hmmm. I guess we'll have to check all the carburetor lines.
SERVICE WRITER
  • 9,123 POSTS
IF there is a brake booster hose on that one, that is what I would first check just due to the size of the hose. More air, the higher the idle. In a sense the carb or throttle body is one large adjustable vaucuum leak.
YATINKV
  • 2004 HONDA CITY
  • 72,000 MILES
My car is 2004 Automatic, Made in Thailand imported in UAE. Recently my car started giving jerks when running at slow speed (between 20KM-60KM). I did not notice the jerks at higher speed. One local mechanic asked me to put Injector cleaning oil in in the fuel tank and after that it worked fine until the next oil change. It started giving the same jerks when I filled the patrol tank. Again I put the same oil in the Patrol tank but this time the jerks not vanished.
I have changed the engine spark plugs and now my mechanic is suggesting the spark plugs coils to be changed for testing.
I'm feeling the jerks and whenever the car stops at red signal I have to either switch off the Air Conditioner or give much acceleration. The RPM needle is not stable also it goes to 2000 RPM and then with jerk it comes to 1500 and then suddenly it change. It is not stable.
The new coils costs too much and he is not sure also that installing new coils will fix the problem or not.
The honda service station is quoting 140$ for diagnosing the problem. Please help me.
With Regards
Yatin
KHLOW2008
  • 41,815 POSTS
Is the Malfunction Indicator Light showing and have you checekd for trouble codes?
YATINKV
Hello KHLow2008,
The engine check light (Malfunction) is not turned on so I did not get it checked from computer. I drove to high way and I felt the same jerks at the speed of 75 miles also. One of the local mechanic suggested me to change the spark plug coils. Kindly suggest.
Regards
Yatin
KHLOW2008
  • 41,815 POSTS
Symptoms do indicate possibility of the ignition coils as the engine seems to be misfiring.
Have the coils tested. Usually only one or two is defective and not necessary to replace all.
NAVEEDZAIN
Hi Yatin,
You got any solution for this? I am facing the same problem with my honda city 2008 model.
Naveed
KHLOW2008
  • 41,815 POSTS
Any update on this?
AZFARWASIM
  • 2008 HONDA CITY
  • 1.3L
  • 4 CYL
  • MANUAL
  • 107,000 MILES
When I'm driving my car, often it operates smoothly and no issues, but on occasions, I do experience a problem, that the RPM increases, even when I'm braking or change gears, the RPM increases, and the engine revs up. The acceleration also increases, but it's under control, not very dangerous. However it's irritating and it's a problem I can't quite figure out as to why this is happening.
HMAC300
  • 48,601 POSTS
Try cleaning throttle plate on both sides an diac hole with choke cleaner.
AKMAL
  • 1998 HONDA CITY
  • 4 CYL
  • FWD
  • MANUAL
When I start engine rpm comes down on o and car switch off.
KHLOW2008
  • 41,815 POSTS
Have the idliong speed readjusted to see if it works.
Get the throttle body and IAC cleaned as well.
MANUF
  • 2001 HONDA CITY
I had an engine overhaul. Since then, the RPM does not stay stable and keeps fluctuating up and down when in drive. The acceleration has also significantly decreased and seems that the car is choking. Had a computerized check up and it suggested high air input. Have tried replacing sensors but that has not helped either. Sometimes the engine starts missing all of a sudden so even tried replacing the distributor but without much luck. Had the plugs replaced with new ones too. Seriously running out of options guys. Please help !
