1990 Isuzu Trooper Repair Question
Topics covered: Engine, Check engine light, Four wheel drive.
Asked on November 8, 2010
1990 Isuzu Trooper
Engine Mechanical problem
1990 Isuzu Trooper 4 cyl Four Wheel Drive Automatic
i have this trooper, the check engine light is on, i did the computer code with the two wires you plug in, in the console, it showed 2,2,2 & 666, which is a 26 code, which is a canister purge vsv, i changed it and the engine light is on and hard to start, i have to turn it over alot, and pump excelerator and it will start but engine light is on, and if i kill it i have to repeat, also it is running pretty ruff, can someone help me out as to what this sounds like?
