Wife's car, she got gas and it started and shut off immediately went and looked at it, we had it towed, a friend who owns a car lot, took pressure reading only had 35 lbs, put in a new pump, filter, same thing, after online research, put new regulator in, same thing, cranked a few time and then it started, drove home. Next morning, same thing, more research, put new crank sensor in, another ion sensor. Every thing works as it should, but same thing. My pressure is about 40, pinched return and it goes to 60+,
Put a noid light on injector, steady flash, pulled a coil and tested for spark, steady spark.
It started once yesterday and ran, after two minutes it shut off and same thing, cranks, starts and immediately shuts off.I have a scanner hooked up and everything that it will give is okay and operating.
SPONSORED LINKS
Do you
have the same problem?
Wednesday, December 26th, 2018 AT 9:39 AM
