Mechanics
QUESTION WATER PUMP/ TIMING BELT
1999 Isuzu Rodeo
Engine Mechanical problem
1999 Isuzu Rodeo Question 6 cyl Four Wheel Drive Automatic 113999 miles
I am trying to get to the water pump to remove because of bad bearing. I am using the strap wrench to hold the crank shaft pulley while trying to take the bolt out; the enine truned about 1 tooth on the timing belt the wrong way. What do I do so that I don't blow the eninge
MJSAY25
May 24, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
