Mechanics
QUESTION REAR AXLE SEAL/BEARING QUESTION
1999 Isuzu Rodeo
Drive Train Axles Bearings problem
1999 Isuzu Rodeo Question 6 cyl Two Wheel Drive Automatic 130000 miles
The right rear axle seal is leaking on my 1999 V6 Rodeo 2 wheel drive automatic.
What holds the axle in?
Do you pull the rear cover to take the C clip off the axle?
Or is the bearing pressed onto the axle and you have to take the 4 axle flange bolts off and use a slide hammer to remove the axle?
Thank you for the help.
Terry s
May 20, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
