Isuzu Other
I have a 1999 Isuzu Rodeo V6 LS 2WD. I was driving down the interstate at 70 with the cruise control on and the A/C on. Suddenly the Cruise control stopped and the A/C stopped. Then a red indicator light on the dash that read A/Temp came on. So I pulled over immediately. Opened the hood. No smoke or anything. Motor running fine and sounding normal. I got back in and put the car into Drive and it would not go into gear. I tried Drive 2 and Drive 3 and still nothing. I put the car in Reverse and was able to back up. I put the car back in Drive and pressed the " Winter" button located on the console and it went into drive with Winter Drive on " lit up on the dash" Once I got up and running down the street the transmission seemed fine but when I came to a stop I had to re-engauge the " Winter Button" to make the car go into gear again. The bilinkers stopped working too and the A/C and Cruise Control still don't work. Is this a computer problem or perhaps just a fuse I need to change? And if it needs a new computer where and about how much do you think it will cost to replace? Thanks George
October 10, 2007.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
