Isuzu Question
Asked on August 30, 2006
2003 Isuzu Other Problem
Upgrade Question
Get Answer Now
Rodeo Reduced Power Check Engine Light Came On!
While my wife was leaving work Check Engine and Reduced Power "Idiot" light came on in her 2003 Isuzu Rodeo and coasted to a stop. The engine kept running but the lights stayed on. She shut the engine off, and then restarted... now the only light illuminated was the Check Engine light. Not having an engine analyzer is there anything that can be done to reset the computer to see if the FAULT goes away? I can only assume that if you disconnect the negative terminal on the battery it should reset the code(s). As for the problem, without hooking it up I would guess that the EGR or Air Sensor is going or has gone bad... what do you think?
Thanks,
Wm. Reid Hoover
Avatar Asked by William Hoover
+ follow question
Replies
There are no replies yet!
Sign in to leave a reply!
Donate
Your Donation Helps
Related Questions
Related Articles
Didn't Find What You're Looking For?
Check Our Main Topics:
