Mechanics
PICKUP FUEL PUMP PROBLEM
1995 Isuzu Other
I have a 95 Isuzu Pickup that will not start. The fuel pump runs when the key is in the start position but stops as soon as the key is in the run position. A friend on mine tested the relays and said they checked out, he said one of the fuse looking diodes on the relay board didn't check out. Any ideas?
Isomage
August 17, 2006.
Replace the diodes if they dont check out if they are not good they need to be replaced it may not solve your problem but oughta prevent more trouble down the road
Speed_6929
Jan 22, 2007.
AD
