1990 Isuzu Other Repair Question
Topics covered: Wheel, Cv joint, Brake pads.
Asked on December 5, 2007
1990 Isuzu cv noise after front wheel bearing repair w autol
i had the trooper with just the front driver wheel off the ground to get at the wheel bearings. when i went to take the housing assembly off i shifted into 4 low to try to keep the hub from spinning, it did not and i believe i put it back into N before i got the drive clutch assembly and the inner cam off. after i repacked the bearings and replaced brake pads i put it back.
now when rolling in N i get two pops for every foot it rolls. first the passenger side cv joint then the driver side cv joint about a half second apart then it rolls a foot or so and then 2 more loud pops from the joints.
any help would be much appreciated
