Mechanics
IS IT A TIMING BELT
1991 Honda Accord • 150,000 miles
Car stopped, and will not start. Engine turns over, but does not start. How do we know if it is a timing belt? Have replaced plugs and fuel filter. Gas is going through to the filter. How can we diagnoise if it is a timing belt? Or something else.
Henefer
May 4, 2013.
Take off the distributor cap and crank the motor to see if the rotor turns.
Do a compression test as well.
Check for spark and fuel pressure as well.
AD
