Mechanics
INSTRUMENT CLUSTER AND ANTI THEFT MODULE
2002 Ford F-150 • 100,000 miles
Having same problem as audi 08r8. Truck starts, as soon as I shut it off it does not start again. All instruments sweep as soon as it does start. When it is not going to start, no sweeping. When it does start all instruments light up and work fine. Dealer tells me I need new Cluster and module, at the tune of over $700.00. If the instrument cluster is lighting and working can I just change the module?
Signsanddesigns
August 29, 2013.
Scan for codes and check fuel pressure first with a gauge
Hmac300
Aug 30, 2013.
Codes check and fuel pump replaced by same dealer. They said there was no fuel pressure. ( If anti theft module is bad would there be any fuel pressure! ) I realize it has been too long a time to complain now, but I had the same problem right after the fuel pump was replaced. And I still have the same problem today. Can I replace the module or do I have to replace the instrument panel too? If I can find out more info I will take the truck to someone who will fix this, unless I can replace the part myself.
AD
Signsanddesigns
Aug 30, 2013.
Modules are vin specific and have to be programmed. Yo have an inertia switch on rh side of dash that couldbe screwing up or just a plain bad connection at fuse box as well. The anti theft could be reprogrammed if that is the problem. Check your ground on engine and battery to body. For fuel pump it'son rh head on a 4.6L you could have a bad dash as well
Hmac300
Aug 30, 2013.
AD
