Mechanics
WATER PUMP REMOVE AND REPLACE
1993 Infiniti J30
Engine Cooling problem
1993 Infiniti J30 6 cyl Two Wheel Drive Automatic
coolant leaking fast from above the pully mounted on the crank shaft. Does this pully need to be removed to replace water pump?If so please tell how, and what size bolts fit into pully to use apully puller.
Ginosantangelo
November 24, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
