1995 Infiniti G20
Transmission problem
1995 Infiniti G20 4 cyl Front Wheel Drive Automatic 157000 miles
My car was and is still running fine. No leak from the Transmission. Then BAMMMM, I went to move it yesterday and it looks like a good portion of the fluid (its red) has run out. Leaving a trail and a puddle of red. It seems to be coming from just under the radiator coolant resevoir on the front right (if you're facing the car). Does this sound more like an expensive transmission repair, or that some hose or connector has broken. Im in Chicago, the weather have been CRAZY here the last few weeks, and I wonder if the zero weather has effected the connections or hoses.
January 12, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
