Mechanics
I HAD TO REPLACED MY CRACKED HEADS AND AFTER REPLACING THEM AND PUT IT ALL BACK TOGETHER IT WON'T START.
1999 Ford Ranger • 178,000 miles
My 1999 Ford Ranger XLT 4 x 4 V6 4. Liter truck had two cracked heads, I took off the heads and replaced them and I put everything back together after replacing my cracked heads, when trying to starting it, it wont start, it has enough juices from the battery, the starter is working, what could be wrong?
Herbertcrocket55
August 26, 2013.
It could be a few things. Are you sure the new heads are good? Have you checked to see if there is spark and fuel getting to the engine? Are you sure the ignition timing was set correctly? What size is the engine?
AD
