I can't find my spark plugs location
MRJHALLER
  • 2003 HYUNDAI SANTA FE
Where are spark plugs located at on my car?
Sunday, July 17th, 2011 AT 5:07 AM
KHLOW2008
  • 41,815 POSTS
Some are under the ignition coil and others have spark plug wires going to them. Here is a guide and the firing order and plug wire locations for you car below. I included all engine options.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Sunday, July 17th, 2011 AT 6:55 AM
ARUSHKHAN
  • 2002 HYUNDAI SANTA FE
  • 4 CYL
  • 4WD
  • MANUAL
  • 91,000 MILES
Hi my car is running on 3 cylinders and tried to take spark plug out of the 2nd cylinder as the dyagnostic machine said it was 2nd that was misfiring and the plug is stuck
Wednesday, January 30th, 2019 AT 11:27 AM (Merged)
  • 31,938 POSTS
Spray lune around base of plug thread, let sit for a few hrs, slowly work plug back in and out to break up any carbon or rust, add plenty of lube spray.
DANIEL18229
  • 2004 HYUNDAI SANTA FE
Engine Performance problem
2004 Hyundai Santa Fe 6 cyl All Wheel Drive Automatic
how do I get to the back 3 sparks plugs ( between the fire wall and the engine)
  • 108,117 POSTS
I get them from under the vehicle, but I have a rack to raise the vehicle. If you have ramps or can safely lift the front of the vehicle, try that.
