Bogs down
DELYNYLED
  • 2002 HYUNDAI ELANTRA
  • MANUAL
  • 130,000 MILES
How can I bleed my fuel line after changing my fuel pump? Is it nessecary?
Do you
have the same problem?
Thursday, March 3rd, 2011 AT 3:09 PM
DOCFIXIT
  • 18,828 POSTS
No will clear any air on start up
Thursday, March 3rd, 2011 AT 3:15 PM
DELYNYLED
I just changed my fuel pump and I am not getting good acceleration. It still bogs like it did before I changed my fuel pump. Heard it may be air in the line. What do you suggest I check?
Thursday, March 3rd, 2011 AT 3:30 PM
DOCFIXIT
  • 18,828 POSTS
Bogs not much to go on would you expand? also recent repairs and last tune. The fuel pump in this vehicle is strong enough to push the air out on start up...
Read this guide, it will help
https://www.2carpros.com/articles/engine-hesitates
https://www.2carpros.com/articles/engine-has-low-power-output
Thursday, March 3rd, 2011 AT 3:46 PM
123YHYUNDAI
Engine Performance problem
2002 Hyundai Elantra 6 cyl Two Wheel Drive Manual
Hi I Bought a Hyundai Elantra 2002 model second hand in 2004, I have had a few issues with it that have all seemed to have passed before I had an opportunity to have them the checked the latest two issues have become a real pain.
Issue number 1
The car is having a real problem accelerating, If I am stopped at traffic lights or slow to turn a corner or in peak hour traffic, it takes a very long time to reach the speed limit and struggles to initially accelerate, to the point that I have to maintain the vehicle in 1st gear to be able to get going and get to the speed required. The revs are high whilst this is happening. I have noticed that the car responds well to pumping of the accelerator which has led me to think that it may be a fuel line issue?
Problem 2
Front head lights keep blowing, and the radio speakers flick from left to right and I get an electrtic shock from touching the consol beneath the cd player.
I look forward to hearing your diagnosis.
Thanks
Jasmine
Thursday, April 4th, 2019 AT 6:47 PM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi Jasmine,
Thank you for the donation.
When the rpm races and vehicle does not pick up speed, you have a failing clutch. It is slipping and not pulling the vehicle.
When headlight bulbs burns out easily, it can either be the quality of the bulb used or there is excessive vibration causing the bulbs to burn off.
Radio ficking from left to right is either due to the stereo system sound which is normal or you have a faulty radio unit if the sound is intermittent.
The electric shock is due to static electricity and it could be caused by accessories such as ionizers, etc. This could also be a problem that is faced by some people and not others. To discharge static electricity from the vehicle, you would need to install a discharge strap froom under body.
123YHYUNDAI
Thank you for the quick reply! Bugger that clutch. It has been a little funny since I initially bought the car.
I will be reccomending this site to every one, Fantastic site! I feel bad that I didn't offer a larger donation!
Cheers
KHLOW2008
  • 41,815 POSTS
Hi Jasmine,
No worries about the amount donated, any amount is always received with thanks and appreciation.
Glad to be of service and thank you for the offer to recommend us to the world :)
If you have further questions, just drop by anytime, we are here to help in whatever way we can and will always give it our best shot.
Have a nice day and thank you for using 2carpros.
MCCURCN
  • 4 CYL
  • FWD
  • MANUAL
  • 118,000 MILES
I am losing power when going up hills and when you first pull out. The rmp's are fine, it idles fine, but just looses power. I can have the pedal all the way to the floor and not pick up speed.
JAYLOW
  • 9 POSTS
Take top timing cover off and check belt condition if you haven't already changed it. If that's not the issue check fuel pressure if fuel pressure is less than 49.8 psi you have a fuel issue. Then change fuel filter if you haven't already then recheck fuel pressure. If that still doesn't fix it check for a fuel blockage and finally key in on the fuel pump. Next check for a clogged cat or resonator. Hope this helps
