Fuel pump pressure?
ZGMN5
  • 2002 HYUNDAI ACCENT
  • 4 CYL
  • MANUAL
  • 10,860 MILES
Dear all,
Could you help me with following two questions? I do appreciate your help.
1. I have a fuel pressure gauge, but I can not find the interface to connect to it. Is there anybody know the location to connect the fuel pressure gauge?
Thank you very much.
Sunday, September 28th, 2008 AT 12:17 PM
On this car you must use an adapter to read the fuel pressure. Here is a guide that will show you how to use the gauge one the adapter is in place. There are some diagrams (below) that will help as well.
On Accent and Elantra, the fuel pressure regulator is a located in the fuel pump. On all other models, the fuel pressure regulator is located on the fuel delivery pipe. The fuel pressure regulator maintains a constant pressure at the injectors during all engine operating conditions.
The crankshaft angle sensor is number 8 in the diagram below.
https://www.2carpros.com/forum/automotive_pictures/12900_pregauge_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_pr1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_cps_13.jpg
More diagrams below!
Please let us know what happens so it will help others.
Cheers, Ken
Sunday, September 28th, 2008 AT 12:46 PM
ZGMN5
Thanks for the reply and picture, rasmataz.
I tried to location those on my car. It seems like that my car is a little bit different from the picture.
I took several photos of my car. Could you point out the delivery pipe testing port and cranshaft position sensor on my photos? Thanks a lot. I appreciate your help.
https://www.2carpros.com/forum/automotive_pictures/248166_Picture_001_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248166_Picture_002_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248166_Picture_003_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248166_Picture_004_1.jpg
https://www.2carpros.com/forum/automotive_pictures/248166_Picture_006_1.jpg
Sunday, September 28th, 2008 AT 6:25 PM
I don't think your car has a test post you will need to use the adapter like the one in the diagram above.
Sunday, September 28th, 2008 AT 10:06 PM
CHEF B
Hi, thanks for the info. I was able to replace the fuel pump and she runs great now!
Here is the pump I used for $28.00 from Amazon
https://www.amazon.com/gp/product/B019BTTT0W/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=2carprcom-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B019BTTT0W&linkId=82d3896eec58ebb66c8bc21604a7bdf0
2Carpros rocks!
Tuesday, February 3rd, 2009 AT 12:26 PM
SHANNIN_DONALDSON
  • 2000 HYUNDAI ACCENT
  • 4 CYL
  • 68,000 MILES
Engine Mechanical problem
2000 Hyundai Accent 4 cyl Two Wheel Drive Automatic 68000 miles
on this veh we had a p1128 and p1124 codes we have replaced the fuel filter the front O2 sensor throttle position sensor and checked the pcv hose for leak and spark plugs. Still not running right car boggs down and has no power we were told that we need to test the fuel pressure can you please tell me how we would do this without going to the dealership thank you for your help
Monday, December 19th, 2016 AT 4:11 PM (Merged)
ZACKMAN
  • 4,202 POSTS
It is your Mass Air Flow sensor.
